troy bilt gtx 20 eaton 11
kubota7800
HI I got a troy bilt gtx 20(13076) with the eaton 11 tranny when the tractor is idling everything works fine but when I give it more throttle the hyd don't work,but if I run it for a 1/2 hr or so everything comes back to life please help thanks
kubota7800
Ok I did change the oil and filter still does the same thing, I even put a can of sea foam in.
Did you bleed the air out of the system as per the instruction in the previous post ?
gainestruk
To bleed air out Jack back tires up off ground, pull the release lever for transaxle (like you are trying to push by hand), move control to full forward hold for 5 seconds then go full reverse for 5 seconds, do this 5 times.
Push release back to driving position then repeat the same as above.
If you can't find release just do it without
You need to have tractor on Jack stands or something that is stable so it won't fall down when you have it in full forward or reverse.
If this doesn't work it might be an internal and you will need to take transaxle and pump out and rebuild it.
Did you check the drive shaft from engine to pump ?
I worked on a Cub Cadet a few years ago that had a pin sheared at the engine side, it would turn pump at idle with just a little movement on control, but when you went half way or full forward it would start slipping and not turn pump.
kubota7800
my tractor don't have the button on the side. Yes I pulled the drive shaft off and the key is there. But why would it come back too life after you use it for 1/2 hr or 45min.
gainestruk
My only thought it might have something to do with filter, did you change it when you changed oil ?
And on the filter it needs to be heavy duty, if you put regular filter on it the transaxle won't act right, if you know origional numbers you might try Cub Cadet, and John Deere, and Napa also I've gotten several heavy duty hydrolic filters from them over the years.
Any one out there have any ideas ??
kubota7800
yes I changed the filer too, I am using traveler premium universal tractor trans/hydraulic oil should I try something different. My book has 2-speed models to use part number 737-0333 no buddy can tell me what tis is...thanks
gainestruk
I remember my Ford LGT 125 that had an Eaton 11 called for 10w30 motor oil, I just looked up eaton 11 oil and the Eaton site says use premium 10w30 or 10w40 motor oil.
