Th3InfamousI
- Jun 4, 2014
- 1
- 3
Hi all!
Not completely new to minor engine repair but I will give you all a run-down of my issue and hopefully someone can point me in a the right direction as I thought I had it narrowed down as a carb issue but alas I purchased a brand new carb after trying to clean the old one about 5x without luck. I had thought that the small vent for the air into the float bowl may have been clogged as that was the only hole I couldn't get a paper clip down.
Anyways....
Its a Troy-Bilt with a Briggs and Stratton 12A-566N063 Tuff-Cut 210 (2003).
I can get the engine to run with a few shots of carb cleaner and then it will die. As it had appeared to be a fuel delivery issue and carb problems are not uncommon on mowers. With the new carb installed it does the same, will only run with carb cleaner. I can confirm that the float is indeed filling with gas and clear fuel line from tank to carb.
I also replaced the spark plug for ****'s and giggles as I purchased the mower off craigslist last year. This mower worked 2 weekends ago just not last weekend so this isn't an old issue.
After replacing the carb to no avail, I tried unhooking the spring to ensure the carb stayed at full throttle and that did not help either.
I'm at a loss here in what to try next? Can't afford a new mower but already got a notice from the city to mow the lawn so I need to get it done this weekend.
Appreciate anyone's help and assistance to the matter.
Anyways....
