MrCollins
- Feb 2, 2021
- 1
- 1
Hello everyone!
I have a Troy Bilt 54" Mustang Zero Turn that I bought in 2017, didnt have much use until 2019, so basically a 2 years of USE mower. I live in the South so there is a lot of heat and use during the summer months. I am relatively meticulous in servicing my equipment. I want it to last.
After purchasing I noticed several things:
#1 There is no where to drain and refill the hydraulic fluid. Is there an internal filter as well? I have consulted my manual and it says that the 'transmission' is sealed and does not require service. That sounds fishy. If I can service this part, what type of oil do I use? I want to use the specific type that it is designed for, brand AND weight.
#2 There are 3 spindles and I would like to swap out the bearings and grease them using a grease gun but there are no grease fittings or zircs that I can see. Is it advisable to take gasket off of one side on each bearing when I get the new ones and drill out a hole for the fitting, grease it up? Is this a thing? I have consulted the manual and I even called Troy Bilt and they told me that they havent put grease fittings on their spindles in 20 years? This sounds like they just want to sell me more spindles etc.
Please advise. I appreciate any help. Thank you for your time.
