I have a Troy-Bilt 33" Wide Cut Mower TB WC33 XP with a 420 cc OHV Vertical Shaft Engine. The lawn mower will run maybe 20 minutes and then dies like it's out of gas. It will then start again but then stop after ~5 minutes of run time...the process repeats with the run duration shortening until it won't start at all. I'll let the lawn mower sit for 20 minutes and then it starts again. I feel like I've tried everything but it keeps stopping. It has 155 hours on it. I've done the following:
- Cleaned carburetor (although it looked totally fine)
- New spark plug
- New gas filter
- Cleaned out air filter
- New gas
What else could I try to fix this?
Here's a video of the lawnmower on how it sounds when it randomly stops:
https://www.youtube.com/watch?v=5JFh46HU0kY&feature=youtu.be
- New spark plug
- New gas filter
- New gas
