Trying to figure out why I get no spark,
Had a mouse problem that exposed the coil wires and killed the engine when clearing snow,
Replaced the coil and still no spark, Traced it to the black ground/Throttle kill switch wire from the coil going to the top throttle plate .
Put a circuit tester from the end of the wire from coil (disconnected)and to throttle lever, There is spark
Connect the wire to the connector no spark
Put the wire end from coil(bare)directly to the throttle lever no spark
Use the tester between the wire and throttle lever, Spark
So why do I get spark when I use the tester
Thanks for any help
Thanks for any help
