Troy Bilt - 16-38HXL - Hook Spring
sk1pmcgee
I need help
The hook spring on my mower deck came out
(Part # 10)
I am not sure how it goes back and the orientation in the mower deck. My mower no longer works because I believe there is a spring that hooks onto the this hook. I am just not sure where Anyone give me a hand
If you love at the diagram you posted it shows you where the hook is attached to the deck. You also need part number 8, the extension spring, which will go between the hook and the tensioner arm. The diagram shows you how they go together.
sk1pmcgee
Does the hook protrude through the mower deck, there is a hole in the mower deck for the hook
Hooks into the deck and will swivel around until you hook the spring up.
Yes, Yes.
