Troy-bill TB110 push mower with Briggs & Stratton 550EX 140cc
Wildfrahm
Good afternoon, looking for some info on this mower. It will start and run for like 5 minutes and die, even just sitting not cutting grass, have replaced spark plug, plug wire and coil, fresh gas & oil, to no availe, don’t have plug tester i can use without a battery. Any ideas guess i will have to pull carb and entire fuel system to inspect. But am suspect of this because it will duplicate every time, fuel systems problem will normally manifest in dying but not same duration whether engine is under load or just sitting. It’s kinda hard to start also, don’t use pull string have cover off and start with drill on low speed setting and takes around 10 seconds to fire, but is a sputtering start then reeves right up and purs like a kitten before sputtering out and dying
