Hi all.
When I put my IS700Z up last fall, it was running fine.  Trying to start it up now, it turns over fine, but will not start.  Sounds like it's not firing at all.  I've put in fresh gas, and had treated the last bit of gas that was in it last year.  It has the Briggs 27 HP Commercial engine.  I suspect that there could be a safety switch that's open - but would that allow it to even crank?   The brake is engaged, PTO is in off position, handles are out in neutral position, seat is down.  Are there any other interlocks that I'm missing?
Are there any schematics floating around, or troubleshooting guides anyone can point me to?
Thanks for any help you can offer.
Steve
