thanks for the help all...i got it running again. i tested the fuel pump, worked fine. so i took off the carb to clean it again in case i missed anything, and noticed an o-ring that sits b/w the fuel bowl and the rest of the carb was pinched and blocking a jet.
i must have gotten it cleaned out and then pin
ched it while reassembling the carb. runs like a champ again.
thanks to all that gave advice.
