clicks then keep trying will finally turn over
J jkbonner Forum Newbie Joined Mar 27, 2015 Threads 1 Messages 1 Mar 27, 2015 / trouble starting zero turn time cutter/kholer engine/just #1 clicks then keep trying will finally turn over
NorthBama Well-Known Member Joined May 28, 2014 Threads 9 Messages 936 Mar 27, 2015 / trouble starting zero turn time cutter/kholer engine/just #2 1- Good battery? 2- Good solenoid? 3- Good starter?
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Mar 27, 2015 / trouble starting zero turn time cutter/kholer engine/just #3 Does it only do this if the temperature is below 50f ? The timecutters have a bad design. The engine has to turn both the drives even when trying to start the engine. When cold the oil in the drives is thick and makes the engine hard to turn over.
