- Feb 19, 2020
- 123
- 12,913
You must read and understand the instructions:
This means any unused wires are just tied to the intake manifold. Don't cut it as it powers the fuel solenoid on the carburetor. It means that you do not allow any bare wires to touch the manifold they must be insulated metal contact and each other. Common sense applies here.Wire tie any excess length wire, including the RED lead (12 volt constant), to the manifold. Make sure all wiring is away from the fan.
