jekjr
- Jan 3, 2013
- 271
- 1,969
Do all of you run string heads on your trimmers or do any of you run any other kind like the ones with the plastic looking little blades?
If string do you run the bump type that advance the line or do you use one of the rapid change ones that uses the pre-cut lengths of string?
