davbell22602
- Nov 27, 2011
- 1,324
Yes when looking up the camshaft and timing gear. The original timing gear was plastic but superceded to a metal timing gear and camshaft has plastic sleeve on the metal shaft.Since you said flywheel key is intact I suspect a camshaft timing issue as I see ignition kick back. This engine has a plastic camshaft that can slip on the steel shaft.
Chinese or OEM?New carb
How far do they extend into the head?valves move freely up and down
Might double check this. Several people have told us the same thing. 7 pages later of help and we get told the OP had a bad FW key.flywheel key is good,
No thing for a Briggs.60 psi compression
I would say you have a fuel delivery issue.Tries to start but doesnt.
Not fuel delivery issue cause wont even start on carb cleaner. Flywheel was pulled and key was checked. Amazon carb. Doesnt matter where the carb is made its all made overseas now. I have amazon carb on pushmower I use here with no issues for 5 years.Chinese or OEM?
