Repairs transmisson lever not shifting smothlyi
rods0007
I own a craftsman 17.5 hp lt1000 after cleaning it changing oil etc. all of a sudden my shifting lever on my gear shift became harder and harder to shift. It is now at the point that i can hardly move it at all. Can someone please give me some advice on what a may try to fix this problem. I did recently make a brake adjustment because they were no longer stopping the mower. Could this have anything to do with it ? I welcome any suggestions. Thank you Rod
mechanic mark
yes especially if you pressure washed mower, inspect all shift lever parts to transmission, maybe you knocked something loose, if everything looks ok spray lubricating oil on all moving parts.
rods0007
Thank you for your kind response. I tried but couldnt find anything out of place . could it possably nneed gear oil? even though dont recomend you lube the bearing i did anyway.
