I have a JX75 mower and when you turn the wheels lock. Need suggestions please and thanks
B bob68003 Forum Newbie Joined Jun 16, 2013 Threads 2 Messages 2 Jun 16, 2013 / Transmission sticking #1 I have a JX75 mower and when you turn the wheels lock. Need suggestions please and thanks
BBO Well-Known Member Joined Jun 9, 2013 Threads 0 Messages 126 Jun 16, 2013 / Transmission sticking #2 bob68003 said: I have a JX75 mower and when you turn the wheels lock. Need suggestions please and thanks Click to expand... What is the S/N of the mower? (X-???????)
R redbaron Member Joined Jul 30, 2013 Threads 6 Messages 12 Aug 19, 2013 / Transmission sticking #3 same problem the wheels seem to lock when In neutral and trying to turn. x208652
BBO Well-Known Member Joined Jun 9, 2013 Threads 0 Messages 126 Aug 20, 2013 / Transmission sticking #4 redbaron said: same problem the wheels seem to lock when In neutral and trying to turn. x208652 Click to expand... Have you taken anything apart? Go here. John Deere - Parts Catalog Search for LX75, and select your mower. Then in the sectional index you can select section 31 for your serial number. Then look at pages 43 or 44 to see how it's made. I never worked on one of these at all. Maybe someone else can help you more.
R redbaron Member Joined Jul 30, 2013 Threads 6 Messages 12 Aug 21, 2013 / Transmission sticking #5 Fixed cable had sliped and the left drive gear was on backward works great. Now. Thank you
