John Deere Walk behind mower, JS63C
After removing drive V-belt I noticed that the sheave pulley isn't tight around the transmission shaft. There's play in it. Does anyone know if there is supposed to be a bushing in the sheave (pulley) or is the pulley just made to fit snug around the transmission shaft.
The transmission shaft has a pin in it (acts as a key-way), that the sheave pulley sits on.
