transmission problem
ACF
have a poulan pro 300x model pb19542lt , 96042003400. the mower move in forward but will not move backwards when the shifter is placed in the reverse position. have replaced the belt with factory belt still no reverse. the shifter area has no binding. the transmission is a dana d6800-1 from drawing looks like it is all gears inside casing. looking for suggestions as to what could be the problem, my gut tells me that the gear that allows it to go into reverse is not moving inside.
thanks
AC
