mjhartmann08
- May 1, 2018
- 1
- 1
Hi Fellow Cub Cadet Forum-ers,
I recently used my XT1 LT46 (model: 13APA1CT056) for some yard work (hauling a small cargo cart with dirt and rock) and after a couple rounds I began to notice a leak from right rear axle. Not a small leak either, oil is all over the inside of the tire and after letting it sit overnight it left a good size spot on the cardboard.
I am thinking its either the seal (TT-19216334280) or the bushing (TT-168T2034240), and I am concerned about re-filling the oil if the transmission is truly sealed.
Any recommendations on how to either fix or replace? I am hoping a full replacement is not my only option... I will post pictures once I get some.
Thanks for all the help!
