bonecracker93
- Dec 1, 2013
- 25
hello i have this newer craftsman. it started leaking the trany fluid\grease last fallvery slowly oit of where the shifter gose into it. then this spring it started to leak out where the rear axle gose nto it. being that it is a sealed tranny i suspect that there is no way to add fluid. i was thinking i could put new seals in? but i cant seem to find anyseals to by. what should i do? model #24728902
