Transmission Fluid for Cub Cadet GT3200
magnum308
I need to get some transmission fluid equivalent Cub Cadet Drive System Fluid Plus. Is there an equivalent here in Australia I can use?
Or call 1-515-266-7944
See 2000 Series Shop Manual page 40 for filter & fluid change, it should be same as 3000 Series, both are heavy duty. When I clicked on 3000 Series Service Manual it will not pull up.
Use full Synthetic Fluid
Thanks for the responses. I checked the level this morning and seems to be full or near full. So no urgent need. I will call the Cub dealer (here in Toowoomba, Qld) this morning and get him to get some genuine Cub Cadet Drive System Fluid Plus fluid for me to have here (I'm 40 mins north of there).
Obviously after the mow yesterday the fluid (and there's 5 qts or4.7 litres of it) was still in the hydraulic system and has now drained back to the sum overnight.
Cheers, Peter
