Hi, can anyone help me with a routing diagram for the transmission belt on a 2005 JD LR135 Automatic ( also known as SB 92 Hydro), I have spent days researching on the web and have found details for every JD ride on you can imagine, but no info on mine.If it helps, this is how I think it goes , but it means that the "V" side of the belt will be contacting the 2 small flat idlers near the transmission pulley which doesn't seem right to me;
ThanksView attachment Scan.pd.fbelt routing.pdf
