"Training Wheels" to protect ZT's muffler
BanjoJohn
When I raised the front of my Husqvarna zero turn to clean out under the deck, I was limited by the mower's muffler hitting the ground. To protect the muffler, I built a pair of "training wheels" that easily bolt on when it's time to clean under the deck.Deck Cleaning 01.jpg
mhavanti
Good looking set up!
Max
LotusLord
When I raised the front of my Husqvarna zero turn to clean out under the deck, I was limited by the mower's muffler hitting the ground. To protect the muffler, I built a pair of "training wheels" that easily bolt on when it's time to clean under the deck.View attachment 38442
That is clever sir. Well done
FWIW I reverse up some FLAT Topped car ramp first then lift the front.
Used to use all sorts of things to lift the front.
By doing it this way I am not tilting the engine as far so avoid problems caused by oil entering the combustion chamber.
Not as much as a problem with the twins as it is with the singles
