Hi all,
I have a 20hp B&S engine. Brought it to the local repair shop because the battery would be drained after 5-6 weeks. They tested and said there was nothing wrong with the charging unit despite the fact that I am now on my third new battery.
They put a new fuel filter and air filter and I replaced the plug. It starts up fine and will run perfect for about 25 minutes then shuts down. It will crank but not restart. After letting it sit for 5-10 minutes it will restart and run for two or three minutes then it will shut down again. This condition repeats over and over. It has happened several times and can be reproduced.
If it sits for a while and cools down it will run perfect again for 20-25 minutes before the same symptoms appear.
I tested for fuel and spark when this happens and I have both. Was thinking it was the coil but since I have spark I doubt it.
Planning to bring it back to the shop but was hoping for some help here.
Any thoughts would be appreciated.
Thanks.
-Jason
Thanks.
-Jason
