Larry Cramer
Hi Folks, I have a 2006 craftsman 5500, 54" lawn tractor that will start then run for about 15 seconds then stop. To start the engine I have to remove the air filter cover and spray gas into the intake. Then it will start up but then it starts to stall so I hand choke the engine at the air intake. By doing this a time or two the engine will finally start and run. My question is what is the problem and how do I correct it.
Thank You
Larry C
Thank You
Larry C
