When we tow our little trailer up with the tractor, is it bad for the tractor in any way to use it so much? The trailer might be close to 200 pounds and we have to use the equipment about 3 or four times a week. We drive it on the side of the road and its only a couple blocks away. Is this bad for the tractors transmission or engine to be hauling it back and forth all the time? I also use the tractor to cut on some properties.
