Towing with CT151
Eddles
Lately doing some garden work, I've had to move large piles of plant waste and it is very time consuming. I've got a CT151 lawn tractor and a large, light trailer which I'd like to use to help me move the plant waste. The trailer has a standard ball hitch, while the back of the mower at the bottom has a triangular flat steel plate with a hole in which I think is the trailer hitch. What would be the best way to link the two? Should I get a ball hitch like this one and put it in the steel triangle? I may need to widen the hole, but would this work?
Many thanks!
