I have this toro timecutter Z420 with an intek 465 engine. It will run ok when it is cold for about 10 minutes then it will die. I used to be able to "catch" it before it died by throwing the arms out and lettting it set for a few seconds before taking off again. Now it has progressed to the point that I cannot keep it from dying by doing that. If I let it set for about 30 minutes it will run OK for about another 2-3 minutes before it starts this again Here are some of the numbers from the machine. MOdel 74327, serial 260009032. The intek 465 is model 286H77 or 2861177. other numbers stamped on are 0165E1 060301ZD
I changed the fuel, the fuel filter (twice) and the spark plug and it still does this. Does anyone have any ideas what is wrong and how I can fix it? Thanks
