Noob, me takes apart his mower engine because I thought damage was causing a backfire, Not the case I was running the engine without the blade. I did that here : https://www.lawnmowerforum.com/thre...ick-back-is-flywheel-key-damaged.60151/page-2 Now I started to re-assemble the engine but realized I have now idea on much torque I should be putting on the crank cover case bolts or the bolts that hold the engine valve cover ? I am just looking for some rough numbers ? Any hints |
