It now has 8 hours on it and it's time for it's first oil change.  I've read the manual and it seems simple enough although the drain hose doesn't appear to be very long.  The drain end of it is attached to the frame with a plastic tie.  Bear with me if these questions are dumb, but I've never owned a ZTR before.
1. Am I supposed to remove the the plastic tie to allow greater movement (flexibility) of the drain hose or just leave it attached as is? It seems as though it would be difficult for the oil to drain if it is left attached to the frame, but the manual doesn't say anything about removing the plastic tie.
2. Is Mobil 1 synthetic oil okay to use in it?
Thanks,
Scott
Thanks,
Scott
