toro zero turn 74373
Cochiese
mower stopped without blades engaged like switch turned off. Battery good, replaced starter, solenoid, relay, ignition switch, and diode. Still won't crank
I can turn engine over by hand, I can jump across 2 main wires on solenoid and motor will crank but not start. Tested PTO switch and it tested good. Not sure what to check next any ideas?
Here is a procedure to follow before you throw any more money at it.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position q(you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
Cochiese
Already checked vtages as I mentioned in first post, have 12.45 volts on battery side of solenoid. Ground is good. Will check small wires on solenoid.
I used to be a mechanic. I can rewire a car from front to back, at least one without computer. I have volt meter and everything else needed. As stated in first post I have replaced stater, solenoid, ignition switch, relay and inline diode, checked fuses already. Tested small wires to solenoid, no voltage to either one
Post from solenoid to battery has 12.45 volts. I can still jump across large posts on solenoid and engine will still crank, but nothing when key is turned. When in park and PTO switxh off i used to be able to start mower without being on it. There is no brake/clutch lever on this model. Can't attach any pics, files are to big.
Cochiese
Cheched safety switcb under seat and it is good
Cochiese
Latest update have no power running to ignition switch, tried running jumper from battery to small connections on solenoid and nothing happened. Tested voltage to see if one of them was a ground and got nothing from either of the small terminals. Found wire that ran to ignition switch and tested continuity and wire is good.
Catherine
LawnWorld Support
Welcome to the forum!
Hopefully, we can help you get that mower going again.
7394
Yes welcome aboard.. You are in the right spot.
Cochiese
Problem was one of the wires melted under fuse block behind seat. Got rid of fuse block and put in 2 inline fuse holders. Guessing old starter caused problem. At least now entire electrical system is new.
