Toro zero turn 60 pto won't stay on
ajz
Pto won't Steyn on mower dies
Carscw
What?
More info please.
When the mower shuts off will it start back up or is the battery dead?
motoman
You need to look at the engine strength in "run." If weak the PTO load will kill it when it cuts in. By strength is meant -compression, fuel starvation . If ok then extra load beyond PTO like bent blades, spindles etc
