Toro Z5035 transmission problème
Sebastien79
Hello
I have à Toro z5035 have problem with right hydro transmission
When is cold is pretty slow after 5 min is ok
mechanic mark
Click on Service Manual then English & read on. Manual says sealed units do not need to be serviced. My son & I serviced our Simplicity tractor transaxles & used Tuff Torque 5w50 full synthetic oil as suggested. I have a K57 Tuff Torque transaxle in my 2010 Simplicity Broadmoor which is a sealed unit. We drove tractors around block minus decks to get fluid hot. Jacked up rear of tractor & using jack stands, removing transaxles with wheels attached, removed fill plug & magnet, rotated upside down to drain into drain pan, inverted & added new oil per specs. with magnet & fill plug reinstalled, reinstalled transaxle & bled air from system then back around block one mile checking for leaks & operation moving forward & in reverse, everything ok.
Sebastien79
Thank you just read the manual
Try that tomorow
Sebastien79
I mark
I change oil both side and run good now
The only probleme now one side Go Faster
I play with the ajustement to run straight
Now am loosing speed .
mechanic mark
