Changed the battery, now, when the blade switch is engaged it stops the engine. After checking,electrically, the ignition switch,PTO switch,seat switch,kill relay, both park brake switches,and FlyBack diode, all passed electrically.
Another "change" just happened...pull the PTO switch.......... blades do not engage at all.
And, all I did is swap batteries.............Now....Ain't That Weird???
