Toro Z5000
dt0969
I have a Toro Z5000 and I have having a problem with it moving. It starts, the blades engage but it wont move. The transmission belt is fine and the engage and disengage lever for the transmission is set to drive. I was messing with it yesterday and it moved about 20 feet then stopped. I dont believe that the transmissions are both out. Do you have any ideas? Thanks
I'm with you on the transmissions would not have failed at the same time...
but one common belt drives both...
You must have a problem with the drive belt to the two trans drives check the idlers & recheck all the pulleys engagement... :smile:KennyV
