toro z4200
culb
i have a toro z4200 and the ignition switch i bought doesnt have the six terminal can i jump the i wire
Get the correct switch.
They are not that expensive.
You should be able to get an aftermarket one as well.
Take the old one with you when you go to get the new one.
If you cross wire voltage to the magneto you will fry it $$$$$$$.
If the ground wire is missing you will not be able to stop it.
