Toro Z4200 w/ Kohler Courage 19HP
crazyoldtractor
The electrical is where things may nt match up. Things to make sure to hook up: fuel solenoid, kill switch, starter solenoid and wires, stator connections, lights, volt meter, smart spark(if engine has it). I've found whenever I changed engines that were mounted on different brands of mowers, 9 times out of 10 the key switch and wiring harness were not the same and therefor did not work together. Make sure they are other wise you will have to do some custom wiring. And also does the mower have a gravity fed fuel system, or does it require a fuel pump. I have a wheel horse that I put a new gravity fed fuel engine on, but the original engine had a fuel pump. The gas tank was a rear mounted gas tank, not meant to be gravity fed. I ran into some problems there.
