Toro w/6.5hp leaking oil
Rickcin
My Toro is about 12 years old and runs fine but it loses oil. I can see oil with dust & dirt stuck to it around the base of the motor, on the deck and all around the fins of the motor.
I am guessing it needs a gasket ? Since the mower is 12 yrs old does it pay to tear the whole thing apart and how would I determine if and which gasket it is?
Thanks -Rick
possum
Check around the dipstick tube first. The o-rings go bad and need replaced sometimes.
Rickcin
You know what, there is a lot of oil residue there so I guess I fine clean that area and keep an eye on it!
Thanks so much, I will keep you posted!
Rick
Clean the entire deck and then lightly coat the deck with a light powder. Baby, foot, flour etc. Allow it to sit for a couple of days. If no indication of where it is coming from, run the unit for 30 minutes and then let it sit. The powder will show you where the leak starts.
