Hi,
I have a Toro Timemaster Lawn Mower, and it won’t turn off.
I already tested all 3 contact points and there is continuity (when switch is enabled). I also tested switch and it is working. I changed the switch and ground cables to new ones, just in case, but it still doesn’t work.
I already replaced ignition coil, and it still doesn’t shut off. It turns on the first time, issue is when turned off. I tried an Amazon version, and also an original Briggs and Stratton ignition coil, same case, it just doesn’t turn off.
I already tried grounding the ignition coil while running, to the same lawn mower, and also tried connecting a cable directly to a battery’s ground with no success. Problem is the spark plug keeps getting voltage, even when I try to manually ground it. There is no physical break on Timemaster, so I don’t know what else to do.
PLEASE HELP!!!
PLEASE HELP!!!
