Hi I just purchased this mower from mowersdirect.com. It delivered on 7/12, and I successfully used it for a few minutes and then shut it down and put it into the garage. Came home today and the starter was running by itself with no key in the ignition. It was a grinding noise that only stopped when I disconnected the battery. I did try to crank it but it just clicks and pops like the battery is low. It is under warranty, but I have to take it to a dealer and unfortunately have no way to transport it. I'm not a mechanic but am somewhat handy - is there a fuse or something I can replace or what? I just emailed Toro, but doesn't help me if I can't transport the mower. Thanks in advance. Kevin
