Toro Timecutter Mulching Blades
GasSniffer
Hello gents, I have a 34" Toro Timecutter 75734 with a Recycler mulching kit installed.
I was wondering which mulching blades to get as spares?
Could aftermarket blades work or should I stick with Toro blades?
I like the mulching blades that came with the kit, I just want to have some spares that I can keep sharp and swap quickly.
Thanks
Remove one of the blades and clean with a wire brush. You should find the Toro blade number to get as spares if you like them that much. Personally I would stick with Toro blades, but I’m a Toro guy.
They are just standard hi lift blades according the blade images.
