I have a used 2014 Toro Timecutter ss5060 Model #74632. Last week mid-cut the engine grounded/choked out. Since then the engine fires up with no troubles, but every time I pull the control arms in it grounds out the engine, but once in a great while it won't and it'll work for 30-60 seconds then ground out. I tested connectivity on the control arm safety switches, seat switch and PTO switch (which doesn't kill engine). I checked for any loose or frayed wires, the fuses, the oil level, the air filter, charged the battery.
Not sure where to look/test next, any suggestions would be greatly appreciated, thanks, Kirk
