MacArthur
Battery fully charged, sprayed a few puff of carburetor cleaner into the air intake, it will start, but stopped very quickly again, which means spark plugs probably are OK.
Strangely there was some fresh fuel leakage at the input side of the fuel filter. Checked the connector and clamps, both are OK, no cut/broken, still sealed properly. Couldn't figure out where the leakage came from.
There's almost no fuel inside that clear filter. Fuel line between tank and filter is definitely not clogged, I can siphon gas out without any effort. Removed the fuel filter and blew it several times from the output, and I can see some debris inside. My guess is: regardless of the filter, some debris managed to get into gas tank and clogged up the carburetor bad, it "choked" up the whole thing
What do you guys think? Any advice is welcomed!
