Exactly. Anything is possible as that is why I posted the wiring diagram. But it takes knowing what they are looking at on their end as we can't things on this end or know the experience level of person on the other end.Had a similar issue. Turned out a wire passing through a sheet metal housing had rubbed itself bare and was arcing against the metal shorting and blowing fuses.
