thumbscore
- Nov 11, 2018
- 2
- 5
About 15 year old Super Recycler, 20099. I've had a few bad luck problems. First the rear wheel cracked and broke off the rim, I've replaced the wheel and had no issues for the first mow. A week later on another mow, the personal pace cable got snagged on the fence, and pulled out of place in it's clamp on the handle (I heard the sound of the ribbed cable pull and slip in the clamp, rrrrip!). I have not been able to get it adjusted back correctly. The self drive is very weak even if I tighten the cable as much as possible. If I reach under and pull the bare cable with a finger while mowing, it engages fully. Also the right rear wheel is now locking up when I try to pull the mower backwards, after personal pace is engaged and then stopped. When the mower isn't running or if i start it and don't engage the self drive, it seems to roll forward and backward normally.
Am not sure how to adjust correctly..? I have pulled the cable forward and backward one ribbed 'notch' at a time and can't get it back to working the way it was.
