Kennykenny
- Nov 30, 2013
- 97
| I have a Toro Snowthrower 38518. This winter while using the thrower, the unit worked fine to be able to clear a three-car driveway. I would then shut the unit off and then attempt to restart and do other driveways. When doing this, I would have a difficult time restarting it or if I did get it to start, it would soon die and once again restarting was very difficult. I changed the spark plug 4-5 seasons ago and upon checking it, it still looked good. Suggestions for other things to check to fix this issue? Tuneup items? Thank you. |
