southofmotown
- Dec 8, 2014
- 2
- 6
Newbie here, trying to get this Toro S200 snowthrower to start. I know nothing about 2-stroke engines. Would not start (no spark or engine action) when I pulled the rope, so I changed the spark plug, squirting a little fuel mix into the hole before installing the spark plug. Pulled the rope and no action. I noticed that the starter drive gear was chipped and brittle. It was not engaged with the larger gear that spins when you pull the rope, so I pushed it until it engaged and then tried pulling the rope a few times. On one of my tries the engine revved, but quickly died.
Through all that, the starter drive gear broke (it was only a matter of time). I thought I would order a new one, but have a question: should that starter drive gear be engaged with the larger gear that spins when you pull the rope (don't know what it's called) when I pull the rope to start the engine? If so, what moves that starter drive gear laterally, because I had to move it manually to engage the larger gear?
Thanks for any help. Todd
