I’m working on this Recycler 20334 with a 7hp Briggs, not an OHV engine. It usually starts pretty well on the rope, but not the typical 1 pull start. This mower has an electric start too. I usually will start on electric, but it cranks and cranks and cranks.
I’ve removed and cleaned the carb, I replaced the battery, I replaced the air cleaner, replaced the plug, I ran some Seafoam spray through the intake, I put Seafoam in the tank, and I changed the oil. None of this made it start easier. Based on videos that I’ve seen, the starter speed seems right, it just doesn’t light off like it should. The mower seems like it might have a mild, almost unnoticeable miss sometimes while not under load, yet it runs and cuts just fine. The only thing that hasn’t been touched is the coil and the valves.
Any suggestions?
Any suggestions?
