Integraoligist
- Nov 4, 2012
- 5
- 14
Ok, I had time to pull the flywheel off yesterday... using a new nut and whacking it with a hammer destroyed the top few threads on the shaft but i should be able to get the nut down and tight enough. So anyway the notch for the keyway was almost 180 degrees from the notch on the shaft. How it got that far, she must of whacked something real good, yes?
Anyway I cleaned the entire area off (filled with grease and sludge) I will get the flywheel key tomorrow at the local Toro dealer as they have a couple in stock. But is there a certain way it needs to go on? As it's the L shaped one, so looking down at the notch of the shaft, should it be turned |_ or _| ?
Thanks again!
Thanks again!
