m7atsmith2gmail.com
- Sep 21, 2016
- 2
How did you resolve this issue? Having the same thing--don't want to buy the part for 100.00 and find out it didn't solve the problem! Mine is a Pro Line 36"
Matt
Matt
I need help, grass is getting away from me with all this rain. It's a Kohler CV 12.5 with what looks to be a 15 amp clutch circuit (pull start) on a Toro ProLine 32" mower. Replaced rect/reg on Kenny's advice, 42 VAC at reg AC terminals, 0 VDC B+ to ground. Put original reg back in, same but the clutch will engage when I short relay contacts, but as Kenny advised, clutch gets hot. Observations so far; all switches check for continuity as does wiring, stator measures around .4 ohms with no grounds. Look forward to advice.
Rgds,
Dave
