I have a Toro 20331 22 Recycler Lawnmower and a Toro 51945 Weed Wacker. Both products worked reliably for many years until recently. Both became hard to start so I purchased new carburetors for each and installed them. They both became initially easier to start but then both would not start if they were shut off during an extended period of use unless they cooled off. I purchased a new ignition coil for the mower which made it start 1st pull but it still has the problem of not starting after shutting it off after long use. Any suggestions?
Thanks,
Spike3333
Thanks,
Spike3333
